| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | Hey guys, I got a question about what I thought was a truck frame, now I am not sure. A buddy gave me a rolling chassis that he said was from a 46 half ton. He even brought it to me and I just now took a look at it and I realized that it tapers in width all the way to the back where is is 46" wide. I have had a bunch of trucks and my brothers 40 is a 3/4 ton and all of them have had straight frames once you got to the firewall. This frame has a 235 in it with a 4 speed that has the reverse lockout lever on it and the pedal assy is attached to the bellhousing, it all looks normal to me except the frame. Is this a car frame maybe? it is app 117 inch wheel base, the rear axle tubes expand or get larger at the ends between the springs and the backing plates. The rear springs are 1 3/4" wide. Both ends are 6 lug.
What do you think?
Jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check the resto pack, has car and truck specs Bill | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | Well, I learned something today. I guess I have never had a real 1/2 ton this vintage before, according to the books the 1/2 ton frame tapers and all the other specs match up too.
Jason | | |
