1 members (‘37ChevyPU),
86
Mod | | | Forums66 Topics128,211 Posts1,057,476 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | My truck front drums have an extension on them. Is there a spindle out there I can use to get rid of this?? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What do the extensions look like? | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Bolts to brake drum and extends out about 5 inches. Spindle extends out same amount. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy jetmech6868, those extensions are to allow dual style wheels to be mounted reversed on the front axle. I believe a standard single wheel hub/drum can be mounted on that spindle. | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | I can send you a pic. Where do I send it?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It sounds like you have the extensions as mentioned above, for a 1 Ton dually. I don't think there is such a thing as a 3/4 Ton dually from the factory so maybe this is someone's creation. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes these sounds like the extensions for a dually. It's hard to know what someone was thinking when talking about stuff done to a 60 year old truck. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The 3600 and 3800 trucks used the same spindle. Is it possible you actually have a 3800 truck? Or, like a pevious post, someone may have put the extension on from a dually truck. | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Well vin says its a 3600. But I guess they are extensions. So the fun part is finding correct hubs to put on. Thanks for the help... | | |
