1 members (Steve_H), 186 guests, and 1 robot.
Topics128,162
Posts1,056,934
Members48,458
Should I stick with the 3OTT after a upgrading to a 3.55 ring and pinion from Patrick's or will the granny 1st in a SM420 4spd actually become usable for street driving?
I'm looking to gain a bit for the highway without killing my 216 but I don't want to lose too much off the line power. My thinking was that the 4spd with the 3.55 might be a good combo. ...and an easier/cheaper task than a T5/open drive/new rear swap.
Also, In trying to keep all the hot rodding somewhat traditional, a T5 just doesn't seem right.
First gear will still be useless with 3.55 rears, but your other gears will be more roadable. Reverse will still be terribly slow. Patrick used to recommend a 4 speed passenger transmission from the 60's, but they are getting hard to find and I'm not sure if the adapters to adapt them to the torque tube are still available. Just a plain old SM318 3 speed does a pretty good job in front of the 3.55 rears.
the 3.55 won't bog you down - unless you're planning to carry pretty heavy loads, the granny 1st won't be any more useful than with a 3.90
That's good news, I'd rather keep the 3OTT I've got. As it is, with my 16x7.00 tires I do just fine on the highway with the stock running gear but I'd like to make longer drives (+/-5hrs) a bit less worrisome.
The 3OTT transmission will keep you from violating the 'NO BURN-OUT' policy at the Cruise-ins.
HA! ...but the 216 already does that. wink
When you guys change to the 3:55 gears, do they sell speedometer gears to correct the speedometer??
Yep. Patrick's has em listed near where the 3.55 ring and pinion is listed.
