0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | Truck is a '54 1/2ton, stock drive train and suspension. I've seen all the under the bed applications from supplliers like Brothers and LMC with fillers in the bed floor, but my customer is looking for something different. Showed me a pic of a truck with the filler neck out the side of the bed in front of the back fender. I was looking on the Jim Carter site for a gas tank for my personal '54 panel truck when it dawned on me that the filler neck might be in about the right place for what my customer wants. Anyone ever done this, or done it with some other tank from a different vehicle? | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | any particular reason the stock location won't work? Is it because they don't want the tank in the cab with them. If they get in a bad enough wreck for that to become an issue they are very likely not going to be alive enough to worry about it. (just think about it a little bit) however if they want to move it for more room in the cab or something, that is another story. It is very possible the set up you are talking about may work, but there will be plenty of fab work involved most likely. | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I used Jim Carters set up on my "52" 3100 and it worked perfect. The filler came out so it just missed the front bed stake. I installed a "48" cab on my "52" so there was no gas tank in the cab. The Jim Carter tank and bracket is just a replacement for a original under bed tank. This looks to me to be a much safer location then behind the rear axle as many under bed tanks are.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | Brokenhead, a previous owner has already patched up the filler neck hole in the cab. The guy isn't changing a lot from stock on the truck, just little touches like this, a/c, and a drop axle setup.
Bart, did the filler neck catch the bottom of the bed so that you had to notch the wood, or did it exit below the floor line? The one he had a pic of just caught the edge of the floor so they had to fab a guard for inside the bed.
Fab work doesn't scare us, it's what we do. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Bart - I'd like to see a picture of that tank, in fact if possible, several pictures of where it is and how it is mounted and supported. I've had the same location in mind for my truck. Please send pics to my email address: [email protected]I would really appreicate it if you can! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | I made a large tank for a '52 and theres' tons of room. The filler neck comes thru the bed shhetmetal but below the bed floor and is in front of the rear tire. Looks factory. I don't know how to post pics but can email them.
A shop is where you wash your hands before you pee.
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | The '48 model had the tank under the bed, and the filler came out the right side of the bed in front of the fender. So a replacement '48 tank with filler neck should do the job. Here's some pics of mine. These should show how it's mounted and how it orients to the bed side, the frame and the bed supports. It comes out right behind the cab and below the bed: original tank with filler neck original tank with filler neck original tank with filler neck filler neck I had a new tank fabricated that incorporated the original filler neck. You may be able to do that cheaper than buying a replacement tank. Just find a local welder. Mind is aluminum, to eliminate rust. new tank | | |
