| | | Forums66 Topics128,109 Posts1,056,271 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | i will be puting a ax-15 jeep? 5 SPEED IN MY 64 C20. IT HAS A ELECTRIC SPEEDO IS THERE A KIT TO GO BACK TO STOCK? IS THERE A ELEC GAUGE I CAN BUY? THANKS ART | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, you can find adapters to run a mechanical speedo, or you can get an electronic speedo, although maybe not one that fits in the dash the same as the stock one .... one place for electronic, google for others and adaptersBill | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Speedhut Gauges has GPS speedometers. They work regardless of your gear ratio. Just some wiring involved. | | |
