0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#980243 10/22/2013 12:19 AM
I am working on the wiring harness for my 46 head lights. Does anyone know if the center contact of the head light connector (pin 2) is the common between high and low beam? The head light ohms to zero between all pins so I can't tell. Worse case will be hook up the head light. Thanks.
GW,
Turn the 3 prong head light plug facing you with 1 terminal on the bottom and 1 terminal on each side. The terminal on the bottom should have a Brown wire (ground) the terminal on the left, Black wire (low beam) and the terminal on the right, Green wire (high beam) The wires should go to a terminal board on each inside fender.
Here is the wiring diagram for the 46.
http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/46truck.pdf
Good luck with your project,
Harold
shake
Harold
Thanks Harold. I figured the center was ground. The insulation is gone on my wires.
