6 members (Guitplayer, Gdads51, Gray_Ghost, sron48, MRMEROTH11, 1 invisible), 89 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#9799 01/10/2003 1:19 PM
I need to replace my exhaust manifold '66 250 c.i. I would rather just do the exhaust, and not the intake/exhaust combination. Is that possible, with the one piece gasket? Any tricks to this procedure?
#9800 01/10/2003 8:02 PM
IMO If it is a stock setup you'll want it on the bench before you try to separate the intake and exhaust. The bolts are usually very rusty and will break if you don't heat them up with a torch first. It's all coming off to get the new gasket in, so don't make life difficult by trying to remove just the exhaust.
#9801 01/10/2003 8:24 PM
The whole thing has to come off, the gasket slides on over the studs.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#9802 01/11/2003 6:47 AM
Like they said, you need to take them both off. Don't separate them unless you have to. Whenever I replace the manifold gaskets on the six, here's what I do to help stop the exhaust leaks.
First, clean the mating surfaces. Sand down any rust, remove the old gasket material, and finish the cleaning with a good solvent, I prefer lacquer thinner.
When ready to re-assemble, I put a coat of Permatex Ultra-Copper RTV on the manifold surfaces, then put it all back on. I have used the knock-off rtv, but the Permatex sticks better.
Fred
52 3600
69 C-10
#9803 01/12/2003 3:50 AM
I highly recommend having the manifold resurfaced by a competent machine shop.They will resurface the intake to exhaust if needed as well as replace broken studs/bolts(extra cost of course)
