| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 18 New Guy | | New Guy Joined: Nov 2012 Posts: 18 | I need some help! I have a 1966 C60 2 ton and I am trying to pull the 327 out of it without pulling the transmission as well. I have taken out the floor pans on the inside. (the ones that bolt down above the transmission) so i have taken out 4 of the bolts that i could reach from the inside. When i went underneath to find the rest of them i couldn't. How many bolts are there all together and what are their locations... do i need to take off the starter and oil filter to get to them? Im still kinda a newb with all this so any help would be great!!! thanks in advance! oh, and it is a 4 speed manual with 2 speed rear
1970 Monte Carlo 1966 Chevy C60
* Winning is everything. The only ones who remember you when you come second are your wife and your dog. – Damon Hill
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It may be easier to split the engine at the bell housing to block. Remove the bell housing bolts that go into the block. I think that you have mounts on the bell housing that hold it to the frame. | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | Traditionally there are 6 bolts holding the bellhousing to the engine. It sounds like you have not removed the bolts below the alignment pin on either side. They may be covered in gook and you might have to dig for them. If the starter is bolted to the bellhousing, I suggest removing it as well. Remember to remove the sheet metal lower dust shroud from below, it has to come off too.
I hope this link works, it is a drawing of the rear of a v8 block:
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=Mc0gaJwrdRv5lM&tbnid=2BDc_IQF5hZn_M:&ved=0CAUQjRw&url=http%3A%2F%2Fgrannys.tripod.com%2F20102b.html&ei=2zhlUoP5JsX12wWnk4HgAQ&bvm=bv.54934254,d.b2I&psig=AFQjCNEvWdiGD0RfqTP70THNZoJoo-OJ5A&ust=1382451775825346
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Nov 2012 Posts: 18 New Guy | | New Guy Joined: Nov 2012 Posts: 18 | Unfortunately Macgyver37, that link didn't work. I am sure they are covered in crud since the rest of the trucks underneath is covered. Sounds like i need to just start scraping and searching.
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Nov 2012 Posts: 18 New Guy | | New Guy Joined: Nov 2012 Posts: 18 | That one worked!! Thanks!
| | | | | Joined: Oct 2013 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 23 | Hairy, you might want to double check things. Your truck should have a 13" clutch. This takes a different bellhousing. I would have to go out and check my C50 to double check the number of bolts. | | | | | Joined: Nov 2012 Posts: 18 New Guy | | New Guy Joined: Nov 2012 Posts: 18 | Thanks mrolds, I havn't had a chance to go exploring after my last reply so yes i will definitely do some double checking!
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If the larger bellhousing, also used by GMC, sort of circular bolt pattern, there might be a .25" adapter plate sandwiched between the bellhousing and engine. The trans./bellhousing should only have 4 bolts, however, the bottom ones might have the heads inside the belllhousing(threads in trans.)
