0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
I need some help! I have a 1966 C60 2 ton and I am trying to pull the 327 out of it without pulling the transmission as well. I have taken out the floor pans on the inside. (the ones that bolt down above the transmission) so i have taken out 4 of the bolts that i could reach from the inside. When i went underneath to find the rest of them i couldn't. How many bolts are there all together and what are their locations... do i need to take off the starter and oil filter to get to them? Im still kinda a newb with all this so any help would be great!!! thanks in advance! oh, and it is a 4 speed manual with 2 speed rear
1970 Monte Carlo
1966 Chevy C60
* Winning is everything. The only ones who remember you when you come second are your wife and your dog. – Damon Hill
It may be easier to split the engine at the bell housing to block. Remove the bell housing bolts that go into the block. I think that you have mounts on the bell housing that hold it to the frame.
Traditionally there are 6 bolts holding the bellhousing to the engine. It sounds like you have not removed the bolts below the alignment pin on either side. They may be covered in gook and you might have to dig for them. If the starter is bolted to the bellhousing, I suggest removing it as well. Remember to remove the sheet metal lower dust shroud from below, it has to come off too.
I hope this link works, it is a drawing of the rear of a v8 block:
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=Mc0gaJwrdRv5lM&tbnid=2BDc_IQF5hZn_M:&ved=0CAUQjRw&url=http%3A%2F%2Fgrannys.tripod.com%2F20102b.html&ei=2zhlUoP5JsX12wWnk4HgAQ&bvm=bv.54934254,d.b2I&psig=AFQjCNEvWdiGD0RfqTP70THNZoJoo-OJ5A&ust=1382451775825346
1937 GMC T16 468 BBC th350, 4.10
1941 Dodge COE 5.9 cummins, 9 speed roadranger
1947 Diamond T COE, hercules and 4 spd, all original
1955 Chevy LCF 9.0L IH diesel AT545
1962 Corvair (Elsie)
1967 Jeepster Commando
1968 K10
1970 Chevy C50 box truck
Unfortunately Macgyver37, that link didn't work. I am sure they are covered in crud since the rest of the trucks underneath is covered. Sounds like i need to just start scraping and searching.
1970 Monte Carlo
1966 Chevy C60
1968 K10
That one worked!! Thanks!
1970 Monte Carlo
1966 Chevy C60
Hairy, you might want to double check things. Your truck should have a 13" clutch. This takes a different bellhousing. I would have to go out and check my C50 to double check the number of bolts.
Thanks mrolds, I havn't had a chance to go exploring after my last reply so yes i will definitely do some double checking!
1970 Monte Carlo
1966 Chevy C60
Crusing in the Passing Lane
If the larger bellhousing, also used by GMC, sort of circular bolt pattern, there might be a .25" adapter plate sandwiched between the bellhousing and engine. The trans./bellhousing should only have 4 bolts, however, the bottom ones might have the heads inside the belllhousing(threads in trans.)
