2 members (3B, Cosmo),
149
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | I've upgraded my 65 C10 to power steering. As I'm installing the pitman arm, I realize the drag link is touching the frame. It also look like the DS inner tie rod joint might hit the frame also. I have not torqued it all up yet just in case I have to break it back down.
My parts are as follows...
Rez PS adapter plate 1975 PS gear box 1975 Pitman arm 1965 original drag link 1965 idler arm
Any help would be appreciated.
Thank you Tim | | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | Can anyone tell me if there is difference in the drop on the K6131 and the K6143 pitman arms? If there is, this might be my issue? I purchased the pitman arm from Oreilly's and they gave me the K6143.
Thank you Tim
| | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | Issue solved. Once I torqued it all up there was clearance.
BTW, if you upgrade to PS and your new 73-87 PS unit does not come with the Pitman Jam nut, don't waste your time with Oreillys, Autozone, Advanced, Napa or the local Discount Auto parts stores. Go straight to Fastenal. Get a 7/8-14 Jam nut part# 1136268 $1.20 and 7/8 split washer part#113364 $0.44.
Thanks | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Tim, If you need any more help, just let me/us know. We're here for you. Ummmmmm . . . . sorta, . . . well maybe . . . . we're here, just not paying attention.
Seriously, I'll have to go to your BLOG again and see what U are up to.
Jay
| | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | Jay, I will be updating the blog with more pics this week. I promise to add comments and details to the pictures soon. It's not much of a blog without comments...LOL.
I appreciate the help I receive. Your site is awesome gives me inspiration to keep wrenching away!
Tim | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Tim,
Steering stuff can get pretty arcane at times. The KEY here is MOST '63 - '87 pieces will interchange as long as you stay in the same series; C-10, C-20, C-30. Somewhere around 1970, the A arm bushings changed from bronze to nylon/plastic. Some time around 1980, GM switched from SAE to metric/o-ring fittings on pumps and steering boxes. Power steering MUST have the matching pitman arm, and manual steering MUST have it's specific pitman arm. No exceptions. Idler arms SEEM to all be the same, but there are several part numbers. I personally like to get everything I can from a doner truck and rebuild what needs it in order to keep all the pieces the same year model, but that is just me. I have been told that there are different tie rod end sizes within the C-10 series, but I have NOT run into this.
I'm sorry this is late and I hope it is a help. Use this info any way you want, but NEVER take it as a bottom line!
Best wishes,
Les | | |
