5 members (Chris's 46 / 515, Hanks custodian, Goach2, mick53, 1 invisible), 68 guests, and 6 robots.
Topics128,188
Posts1,057,215
Members48,465
Got the horn now need the relay. But what I need more than that is a picture of where the relay origionaly mounted. Some one mounted 2 horns on the firewall on the old 41. I was suppose to have 1 horn mounted on the intake. I need a pic. or at least a good discription of where the horn relay mounted. I am thinking that the 3 holes near the steering column at the bottom of the firewall is the place. But if I am right the relay would have been about 3 inches squear. Seems kinda large for a relay.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Ex Hall Monitor
Ex Hall Monitor
The intake mounted horn on my 38 doesn't go through a relay. The accessory (twin) horns do. I have a switch to select which I use.
Hummm! The area I discribed looks as if at one time it had somthing mounted there. The paint is a shade differant in a 3 inch squear and the 3 holes look factory. What was there?
I just looked at my manuel Tiny, there ain't no stinking relay on the truck but with the car there is. My manuel has the wiring diag. mislabled the truck diag. is labled car and the car is labled truck. I hope the wiring is correct.
MISTERY SOLVED! Thanks.
