| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97977 11/06/2006 11:57 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Got the horn now need the relay. But what I need more than that is a picture of where the relay origionaly mounted. Some one mounted 2 horns on the firewall on the old 41. I was suppose to have 1 horn mounted on the intake. I need a pic. or at least a good discription of where the horn relay mounted. I am thinking that the 3 holes near the steering column at the bottom of the firewall is the place. But if I am right the relay would have been about 3 inches squear. Seems kinda large for a relay.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#97978 11/07/2006 1:10 AM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | The intake mounted horn on my 38 doesn't go through a relay. The accessory (twin) horns do. I have a switch to select which I use.
#97979 11/07/2006 4:45 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Hummm! The area I discribed looks as if at one time it had somthing mounted there. The paint is a shade differant in a 3 inch squear and the 3 holes look factory. What was there?
#97980 11/07/2006 4:54 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I just looked at my manuel Tiny, there ain't no stinking relay on the truck but with the car there is. My manuel has the wiring diag. mislabled the truck diag. is labled car and the car is labled truck. I hope the wiring is correct.
MISTERY SOLVED! Thanks.
