7 members (1955 1 Series, cmayna, Gray_Ghost, JW51, Pete1946, 55shaker, 1 invisible),
157
Mod | | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 21 New Guy | | New Guy Joined: Apr 2013 Posts: 21 | Sorry if this is a repeat question, but I am rebuilding a 235 GMC, 1941 half ton . I removed the pan and the screen on the oil pump is completely deteriorated. Cannot seem to find one. Any suggestions ? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I use a piece of the perforated aluminum metal intended for leaf traps over household gutters. It's much thicker and more durable than window screen, and it's pretty simple to cut and form it into an acceptable-looking strainer screen. Wrap it over the outside of the pickup can and secure it with a big radiator hose clamp. It will strain out the rocks, marbles, and other big chunks that could damage the oil pump gears. Jerry
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Jditt, I have a NOS early oil pump screen, that I was never able to exactly ID. If you can provide any dimensions I can check against mine, you are welcome to it if it would work.
Drew
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | DrewP,
If it doesn't work for jditt, I am looking for one for the '48 235. bottom is eaten out. I'll send some dimensions if he doesn't take it. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2013 Posts: 21 New Guy | | New Guy Joined: Apr 2013 Posts: 21 | thank you for the offer, sorry for the delay in responding, been out of country on business. If offer is still there, I will send dimensions.
thank you again | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Screen no longer available.
Drew
