0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#978898 10/15/2013 9:41 PM
Sorry if this is a repeat question, but I am rebuilding a 235 GMC, 1941 half ton . I removed the pan and the screen on the oil pump is completely deteriorated. Cannot seem to find one. Any suggestions ?
Jditt #978963 10/16/2013 2:16 AM
I use a piece of the perforated aluminum metal intended for leaf traps over household gutters. It's much thicker and more durable than window screen, and it's pretty simple to cut and form it into an acceptable-looking strainer screen. Wrap it over the outside of the pickup can and secure it with a big radiator hose clamp. It will strain out the rocks, marbles, and other big chunks that could damage the oil pump gears.
Jditt #979075 10/16/2013 5:10 PM
Jditt, I have a NOS early oil pump screen, that I was never able to exactly ID. If you can provide any dimensions I can check against mine, you are welcome to it if it would work.
Drew
DrewP #979115 10/16/2013 9:36 PM
DrewP,
If it doesn't work for jditt, I am looking for one for the '48 235. bottom is eaten out. I'll send some dimensions if he doesn't take it.
Jditt #979544 10/18/2013 1:55 PM
235 GMC?
Jditt #979579 10/18/2013 4:41 PM
Canadian?
My Blog
DrewP #981685 10/27/2013 1:42 AM
thank you for the offer, sorry for the delay in responding, been out of country on business. If offer is still there, I will send dimensions.
thank you again
Jditt #981714 10/27/2013 4:58 AM
Screen no longer available.
Drew
