5 members (Southerntruck, HandyAndy, TUTS 59, klhansen, Guitplayer), 85 guests, and 0 robots.
Topics128,092
Posts1,056,043
Members48,433
#979321 10/17/2013 3:29 PM
I don't like to assume things because it always backfires on me, but I assume the reason the gear lever is easily removed on the SM420 is for installation reasons. Is it so that I can remove it, install the tranny and install it back on by removing the tranny cover. Also, can the tranny be in gear when doing this? That is to align the splines.
Glory Bound...
The shifter removes/installs more easily in the neutral position, but I've reached into the shift tower with a big screwdriver and shifted the transmission into gear many times. Just put it back in neutral before reinstalling the stick.
Thanks for that info.
Glory Bound...
