5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#979109 10/16/2013 8:42 PM
My original three speed was rebuilt at a shop in Corona, CA 'cause it was popping out of high gear going downhill. Charged me 600.00 for the 'reman' transmission with a one year warranty, but it sometimes tends to gall during shifting and I have a growl that starts about 50 and goes to 65 before it smoothes out. makes my mirrors vibrate! I hear what I think is bearing noise sometimes and I'm wondering just what I got for my 600. U joint is new, new pilot bushing, new engine. Growl does not appear to go away when I let off the gas so I don't think it is the rear end. I can live with it but it is loud and annoying around 50 to 60 mph. Anyone got an idea? This is my 46 1/2 ton and I drive it almost everyday.
Anzan #979118 10/16/2013 9:46 PM
Does the sound change if you push in the clutch at speed?
How about slipping it into neutral with clutch in and then out at speed?
Anzan #979511 10/18/2013 5:21 AM
I'll try that...
Anzan #980738 10/23/2013 4:54 PM
When at speed I pushed in the clutch, foot off the gas, and the growl went away. What does this mean?
Anzan #980761 10/23/2013 6:47 PM
ODSS Lawman
ODSS Lawman
Get the RPMs up while stationary. If you hear growl it's on the engine. If not, it's in the driveline.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Anzan #980784 10/23/2013 7:59 PM
I did rev it up with the clutch in and it was there. Fresh rebuild and supposed to be balanced. Would it be the flywheel? I can live with it but wanted it to be right!
Anzan #980961 10/24/2013 4:01 AM
You have eliminated the transmission and everything behind it.
An out of balance on the engine would be a vibration not a "growl".
You should be able to reproduce it by revving the engine with the truck parked.
I did have one with an odd "rumble" with engine revs. Was a bad motor mount that transmitted engine vibration into the frame.
Anzan #981053 10/24/2013 3:40 PM
A growl when you rev it up can be a sign of a bearing going. I would take the engine out and check the mains, to start.
My 46 GMC on Photobucket
Anzan #981489 10/26/2013 3:12 AM
It seems to be more of a vibration than a growl...my mirrors vibrate causing a blurred image but only at 50 to 60 mph.
Anzan #981507 10/26/2013 4:28 AM
If you slowly increase the engine RPMs with the truck parked, you should create the growl/vibration when you match the 50 mph engine speed. That would be around 3000, 3200 rpm. Watching and listening to the engine may give you a clue.
Possibilities:
Vibration damper, flywheel, pressure plate.
More obscure, iron pistons with a crank balanced for aluminum or mixed aluminum and iron pistons, one spark plug misfiring under load.
Anzan #981699 10/27/2013 3:14 AM
Thanks Jim, I'm hoping i don't have to pull the engine again...but I will if I have to.
