2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | My original three speed was rebuilt at a shop in Corona, CA 'cause it was popping out of high gear going downhill. Charged me 600.00 for the 'reman' transmission with a one year warranty, but it sometimes tends to gall during shifting and I have a growl that starts about 50 and goes to 65 before it smoothes out. makes my mirrors vibrate! I hear what I think is bearing noise sometimes and I'm wondering just what I got for my 600. U joint is new, new pilot bushing, new engine. Growl does not appear to go away when I let off the gas so I don't think it is the rear end. I can live with it but it is loud and annoying around 50 to 60 mph. Anyone got an idea? This is my 46 1/2 ton and I drive it almost everyday. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Does the sound change if you push in the clutch at speed? How about slipping it into neutral with clutch in and then out at speed? | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | When at speed I pushed in the clutch, foot off the gas, and the growl went away. What does this mean? | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Get the RPMs up while stationary. If you hear growl it's on the engine. If not, it's in the driveline.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | I did rev it up with the clutch in and it was there. Fresh rebuild and supposed to be balanced. Would it be the flywheel? I can live with it but wanted it to be right! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | You have eliminated the transmission and everything behind it.
An out of balance on the engine would be a vibration not a "growl".
You should be able to reproduce it by revving the engine with the truck parked.
I did have one with an odd "rumble" with engine revs. Was a bad motor mount that transmitted engine vibration into the frame. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | A growl when you rev it up can be a sign of a bearing going. I would take the engine out and check the mains, to start. | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | It seems to be more of a vibration than a growl...my mirrors vibrate causing a blurred image but only at 50 to 60 mph.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | If you slowly increase the engine RPMs with the truck parked, you should create the growl/vibration when you match the 50 mph engine speed. That would be around 3000, 3200 rpm. Watching and listening to the engine may give you a clue.
Possibilities: Vibration damper, flywheel, pressure plate. More obscure, iron pistons with a crank balanced for aluminum or mixed aluminum and iron pistons, one spark plug misfiring under load. | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | Thanks Jim, I'm hoping i don't have to pull the engine again...but I will if I have to. | | |
