1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Greetings Bolters.
1948 Chevy 3100 project. When I try to bolt the ball housing to the rear of 4-speed manual transmission (all original parts), it won't come together. The bolts are incredibly hard to tighten and the four holes are bending and still leaves a gap. Any suggestions? It appears that the driveline is lower than the transmission, i.e. coming in at a lower angle and not straight in. Do I need to jack up the rear diff to improve this angle?
Thanks in advance. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You can raise or lower the front of the torque tube for alignment. The rear differential on these trucks pivots in rubber bushings where they fasten to the rear springs. The ball housing should be able to be slid off the front end of the torque tube. John | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That U-joint ball should be free to slide. Is the ball seating, if not it must be binding up on something. Sure you've got the cork in properly and it didn't slip out?
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | From the sound of it Dave, I think the ball collar isn't drawing up tight. He says he's bending the tabs on it, which to me would indicate that either the ball or the collar is binding up on something.
Denny G
| | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Thanks for the replies. The ball from the driveline doesn't move around. It seems to bind on the top surface and looser on the lower service since it enters this union at an angle, i.e. the driveline angles up to meet the U-joint. The transmission shop that restored my rear diff/driveline found a new ball joint collar and it came with a rubber seal so I simply left this in place instead of using the cork gasket. I wonder if this makes a difference. I am hesitant to take the U-joint apart again.
I appreciate the expertise. | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | I use a tie-down ratcheting strap wrapped around the left frame rail and torque tube to pull it into alignment. Once aligned it should slip into place.
Hope this helps Walt Williams La Verkin, UT
