3 members (Otto Skorzeny, Cosmo, Wayne67vert), 100 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#977632 10/10/2013 12:49 AM
Have a '49 3600 with a '57 235 in it. Somewhere I heard that the hoses are the same for both engines. If so, can someone supply me with aftermarket part numbers? Thanks
heavchev #977747 10/10/2013 2:42 PM
I have a 54' 235 in my 50' 3600 and these are the hoses I am using with the original type radiator.
Lower-Gates #20230
Upper-Gates #21942
heavchev #977771 10/10/2013 5:47 PM
If your 57 engine has a modified water pump on it there will not be a stock lower hose that will fit correctly. The 1955-62 pump is designed to use a larger hose.
It you are using my adapter with a 1941-54 pump than stock hoses like Brad listed will fit.
My Blog
heavchev #978920 10/15/2013 11:10 PM
Filing station is offering a new custom hose for this application now.
Item #GR-646
http://www.flickr.com/photos/advance-design_parts_co/10299446396/
