7 members (wilbur53, GMCJammer51, J Lucas, 3B, walter74, dt235sd, JW51),
108
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | Occasionally ebay has brass tags for carburetors for 1934 models, how do I know which number is correct for my carb, is it the same as the part number?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | This link will explain the numbers that should be on the tag that would have originally been on your carburetor (assuming your carburetor is original): http://www.thecarburetorshop.com/CarterChevroletW1.htmJon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | What holes are they talking about when they say 2-hole or 3-hole airhorn? Carb. could be 34 or 35.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jon, looking thru the pictures that you have posted of the W-1, I notice two things about your rebuilt carburetors. One is the die castings appear to have been bead blasted, do you do that to all the die castings? Two is the cad plating on the steel rods and arms, do you replate all of the steel parts if I were to buy a rebuilt from you? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Denny - many companies would glass bead zinc alloy castings to remove the casting residue for cleaning prior to dipping them in the chromate solution for protection; which is why we did the same thing.
As for the plating of steel pieces: Carter was located across the street from Howard Crown plating, and steel pieces were shipped across to Crown after they came from the stampings shop, AND PLATED WITH WHATEVER CROWN WAS RUNNING THAT DAY FROM YELLOW OR WHITE ZINC, OR YELLOW OR WHITE CADMIUM.
In the earlier years, Crown ran a lot of white zinc, which is the finish we used on Carter items UNLESS the customer had a preference for one of the other finishes.
So, if you purchased a restored carb from us then that is what you would receive. HOWEVER, we have been forced to cease carburetor restoration. Our primary focus has always been on the manufacture of carburetor rebuilding kits, while the restoration of carburetors a secondary focus. Thanks to the deathanol in our fuel, the demand for our rebuilding kits is now at a 40 year high! We have not restored a carburetor in over 2 years. We do have quite a few Chevrolet W-1's on the shelf that we had restored, but sold out of 483's and 574's (maybe others).
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for the inside info Jon. Hope the kits keep going as they are for ya. Are you distributing to any of the vendors that we're dealing with for old truck parts? I've used you kits in the past and would gravitate towards retailers that handled them. Thanks again, Denny Graham Sandwich, IL
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Denny - I hesitate to post such a list on this forum. If you will send me an email, I will be happy to send you such a list; or if the owners of this forums do not object, I would be happy to post it here. Just don't want to post something that might be objectionable to the owners.
There is a very fine line between answering questions, and advertising, that I do not wish to cross.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sure Jon, I understand that, just was wondering if you were the sole source for your kits. I'll pm ya.
Denny G
