4 members (rfs56trk, Hotrod Lincoln, dgrinnan, Otto Skorzeny), 108 guests, and 2 robots.
Topics128,164
Posts1,056,968
Members48,458
I have a 52 1/2 ton with a stock 216. The exhaust pipe donut has started leaking. I have unbolted the exhaust pipe from the header, but the old donut appears to be firmly attached to the exhaust pipe (which is in good shape, so I don't want to bugger it up). What is the best way to remove the old donut with out messing up the exhaust pipe? It's kind of hard to get to, so I'm thinking of taking the exhaust pipe off at the muffler.
My dad always told me, "Don't force it, get a bigger hammer".
It is not made of metal so you could chip it in half.
1951 1 Ton Completed
Sometimes they have a steel sleeve on the inside of the donut that goes into the top of the exhaust pipe and they get rusted and stick. Spray it good with some penetrating oil. And as said above you should be able to split it to get it loose.
