| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | I have dash lights that work on the gauges but not on the speedometer. I put new bulbs in and still they are not working. I replaced the original speedometer with a new replica. Any help would be appreciated. Thank you | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Does the replica have a plastic case? Dash lights ground through the socket base. | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | I will check to make sure but I think it is metal | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Is the speedometer bulb getting power? Check the socket with a test light. If it is, then it must be a ground issue. | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | If the case is plastic how could you ground the bulbs to get them to work? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the plastic sockets I've seen have metal clips to hold them in and the socket is grounded to those clips .... otherwise they would have a 2nd wire for a ground, or you'd need to solder a wire onto the socket body and ground that
Bill | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | I checked and the speedometer case is metal. I sanded off some of the paint on the back where the lights plug in and still no lights? Help? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Time to get out the multimeter. Be sure the case is grounded to the dash. Be sure there is voltage to the center contact of the socket. | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | Thanks Cletis, the cash is installed. I scraped off the paint for one of the bulbs and still no light. I installed new bulbs, but now I will use the multimeter. Thank you | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | I checked power to bulbs sockets that go to the speedometer and there is no power. How do I get power to them? Also how do you get the high beam indicator light to function? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | power should come from the light switch, and the rheostat control on the front of the switch may be defective [would likely affect the interior light too] - trace the wire from the dash lights back to the switch and check for power there, including when you turn the knob to dim the lights .... the high beam indicator should connect to the dimmer switch high beam wire side someplace - a shop manual wiring diagram for your year helps Bill | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | All the instrument lights should have a wire coming from the socket. That is the power (or supply). All the power wires should be tied together and connected to the headlight switch. I would suspect if some instrument lights work and some do not the wire to the non-working lights may have a break.
The hi-beam indicator is connected to one side of the high beam floor switch.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | Thank you, I will look for a break in the wire | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | JD, you obviously have a broken wire somewhere in the loom. Your going to have to trace it back till you find the break. You can stick a pin thru the wire tracing back till you find a spot where you have a reading from the pin to ground, that's the spot where your open will be.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | The quick and dirty fix is to run a jumper wire from the nearest working light to the non-working light. I believe all the dash lights are wired in series. | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Actually those lights are wired in parallel, not series. They are tied together inside the harness. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You mean they're not wired like those old Christmas tree lights of long ago Fred?
So,,,,,what did'cha find JD, don't cha leave us hangin', share it with us. Bet it was something simple.
