1 members (WingWright), 103 guests, and 1 robot.
Topics128,049
Posts1,055,680
#978136 10/12/2013 1:35 PM
Well it's getting close to winter hope to have time to drag the poor old Coe in the garage. My question is do I Repower with a 4bt cummins our leave it alone I would like to put a flat bed with a beaver tale on it so I can haul an old tractor to shows and am afraid old engine just might not have enough snort. I can buy an old bread truck with 19.5 tires on it so I though about using whole drive line. It has disc brakes all the way around. Any thoughts would be appreciated
Mr chalmers #978154 10/12/2013 3:26 PM
I would use the drive train from the bread truck as long as the front spindles and front brakes will adapt to the COEs shorter front axle as Grigg here on the Stovebolt page has been working out the bugs on.Just remember if you go the diesel route and don't use a matching drive train you will have to at least change the rear end for gears that will work with the lower rpm engine.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Mr chalmers #978174 10/12/2013 5:36 PM
Moderator
Moderator
2 Offline
I'd vote for a latter model drive train that you can rely on and one that can haul the bread.
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
HevyHauler #978245 10/13/2013 12:05 AM
it would be easier just to adapt the cab to the whole chassis...IF the chassis ( track width )is narrow enough
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
Mr chalmers #978297 10/13/2013 3:06 AM
The only problem with using the whole chassis is these older trucks usually have narrower front axle beems than any modern truck.
user
