0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
I have a 57 with a 265 under the hood. The previous owner in his infinite wisdom...cut all the ignition wires for some reason. I have no idea which wire goes where on the connectors (back side of the ignition/behind the dash) I have purchased a manual and written everything down, but MY connectors don't look like the 235 OR the V-8 version. Here's what I have:
2 green wires, a purpleish wire, a brown wire, and a red fat wire hanging under the dash.
I purchased a used set of dash wires from a bolter on another site. THAT ignition has the same connections that the manual shows for a v-8.
The problem is that the book shows 2 pink wires running into the plug and I have 2 green wires. I also have a light blue wire running from the top of the starter through the firewall and laying in the open.
I am SO CLOSE to trying to fire off the little 265 I can taste the foul exhaust already.
if I could get a picture of the back side of the plug, I would know which connector to pop the wires onto. Another avenue would be to purchase a new wire kit and redo the whole truck. I plan to do this eventually, but I just want to see if the engine will fire or not. If I buy the wire kit, I need one with a generator. If the engine doesn't fire with that, then I am buying a new engine and having to rewire the new kit for an alternator.
Anybody got any help for this one?
Thanks-Dano wink
my truck gets better every day...every PAYDAY smile
look at the back of the switch,,, it should be marked with what the terminals are for...
Another quality post.
Real Trucks Rattle
Dano - if you've got the shop manual wiring diagram it shows what wires go where - the green and purple wires will prolly go to the starter, the fat red one is power from the batt, the brown one will go to the ignition resistor on the firewall - see here for the switch
Thanks guys! Red, that pic is the exact piece that came with the harness I bought used... i am thinking that the 2 green wires are in place of the 2 pink wires. i think i will unwrap the tape and trace each one + use the pic you have provided. maybe a local car bud can come by and give me a hand too... Hopefully I can get this pig fired off soon!!
Dano
