| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Will 59 6 bolt wheels fit a 51 3100? John | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The pattern will,(6 on 5.5) but setbacks/backspacing and such have to be tried. Depends on what wheels are on the 59, stock or?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks bartomos. I'm still debating about keeping the 15's that on my truck or going to 16's. I have a lead on 16's on a rolling chassis, but didn't want to go through pulling wheels if it was a definite no go. John | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There is some GM vehicle with that pattern from about 40's to 90's and onward, A long time anyway. You can't tell if a 6 lug, non exact original wheel will fit until you try on front and back, spin them and turn steering full left and right. Unless someone has them on their truck already.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Just remember when changing wheels to think ahead. Are you ever planning on adding front disk brakes? If so, your original wheels wont work. I wasn't happy with this fact, but nobody seems to care. LOL! Wheelsmith can fix these problems for a price. I am sure there are others. Its not something to be taken for granted. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Most rims work with the disc kits that I have installed. Sometimes you may have to take a little off the calliper casting. No big deal.
