6 members (Hanks custodian, Stovebolt48, gswbbc, cmayna, Maybellene, Tronman), 146 guests, and 3 robots.
Topics128,042
Posts1,055,520
Members48,424
#97761 10/23/2006 4:21 AM
Took the steering wheel off again to try and fix hazard light and signal cancelation -- didnt know what I was looking for and could not see anything wrong. The wiring and plastic gadgets look ok.
Both of those functions are activated by mechanical means and dont need any extra wires--Right?
This wiring is a real problem--I have Rundel's
book Wired for success but cannot connect what's in the book with the wiring on the truck--mostly because in has been screwed with so much. Eventually I'll get it -- Maybe.
:confused:
#97762 10/23/2006 4:25 AM
Get a service manual for your truck, one with the wiring diagrams in it... the mechanism is probably worn a bit, or the spring is missing/weak/broke.
Good luck.
Another quality post.
Real Trucks Rattle
#97763 10/23/2006 2:56 PM
I have a shop manual (1963 + 1965) with wiring diagrams. If signals work the wirning must be ok for the hazard lights--right? and nothing is broken that can be seen on plastic thingy. They are not that old including the wiring. Head scratcher!!!
#97764 10/23/2006 7:11 PM
Do your hazzard lights have a separate flasher unit?
#97765 10/23/2006 10:41 PM
Riding in the Passing Lane
68 was the first year for factory hazard lights. If it has them they were dealer or aftermarket installed or you have a latter model steering column.
1972 Chevy c10 Cheyenne Super
#97766 10/24/2006 3:03 AM
Baldy,
The hazzard lights button or switch is part of the directional system.
Wrenchbender,
Anything is possible on this truck.
