0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97761 10/23/2006 4:21 AM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Took the steering wheel off again to try and fix hazard light and signal cancelation -- didnt know what I was looking for and could not see anything wrong. The wiring and plastic gadgets look ok. Both of those functions are activated by mechanical means and dont need any extra wires--Right? This wiring is a real problem--I have Rundel's book Wired for success but cannot connect what's in the book with the wiring on the truck--mostly because in has been screwed with so much. Eventually I'll get it -- Maybe. :confused: | | |
#97762 10/23/2006 4:25 AM | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | Get a service manual for your truck, one with the wiring diagrams in it... the mechanism is probably worn a bit, or the spring is missing/weak/broke.
Good luck.
#97763 10/23/2006 2:56 PM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | I have a shop manual (1963 + 1965) with wiring diagrams. If signals work the wirning must be ok for the hazard lights--right? and nothing is broken that can be seen on plastic thingy. They are not that old including the wiring. Head scratcher!!! | | |
#97764 10/23/2006 7:11 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Do your hazzard lights have a separate flasher unit? | | |
#97765 10/23/2006 10:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 68 was the first year for factory hazard lights. If it has them they were dealer or aftermarket installed or you have a latter model steering column. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#97766 10/24/2006 3:03 AM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Baldy, The hazzard lights button or switch is part of the directional system.
Wrenchbender, Anything is possible on this truck. | | |
