| | | Forums66 Topics128,130 Posts1,056,706 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 14 New Guy | | New Guy Joined: Sep 2013 Posts: 14 | Have a '49 3600 with a '57 235 in it. Somewhere I heard that the hoses are the same for both engines. If so, can someone supply me with aftermarket part numbers? Thanks | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have a 54' 235 in my 50' 3600 and these are the hoses I am using with the original type radiator.
Lower-Gates #20230 Upper-Gates #21942 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If your 57 engine has a modified water pump on it there will not be a stock lower hose that will fit correctly. The 1955-62 pump is designed to use a larger hose. It you are using my adapter with a 1941-54 pump than stock hoses like Brad listed will fit.
See the USA in your vintage Chevrolet! My Blog | | |
