Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy), 57 guests, and 2 robots.
Topics128,008
Posts1,055,285
Members48,418
#977222 10/08/2013 6:52 AM
I have a 1951 235 with hydraulic lifter and #6 intake lifter is noisy. with the engine running and valve cover off I can push the rocker down with my hand and the ticking gets louder. Now is there any fix for that or do I just replace the lifters. engine casting #3692703 = 1951 235 passenger car with power glide
pjberg #977233 10/08/2013 12:45 PM
You can remove the lifter and take it apart and clean it.
pjberg #977281 10/08/2013 4:15 PM
There can be two things that cause a spongy lifter. Trapped air or a dirty check valve.
You may want to read my BLOG on this topic.
My Blog
thanks
Would the check ball inside the lifter be the problem if its all pitted
pjberg #977422 10/09/2013 2:06 AM
Yes, that can prevent it from sealing against the seat.
My Blog
pjberg #977491 10/09/2013 6:23 AM
X
X Offline
Correct me if I'm wrong, but it is NOT a good idea to install a new lifter on a used camshaft or vice versa.
Daryl
pjberg #977492 10/09/2013 6:32 AM
It is always best to keep lifters matched to the lobe they are worn into.
Never use a used lifter on a lobe it is not removed from.
Although there is a small risk you can usually get away with using a new lifters on a used cam.
My Blog
pjberg #977494 10/09/2013 6:57 AM
Where can I find a new check ball. Mine is all pitted
pjberg #977541 10/09/2013 4:16 PM
What size are they? Loose ball bearings are available.
You may even be able to cut apart an old bearing to get a ball out.
My Blog
pjberg #977711 10/10/2013 7:38 AM
I found one ball bearing at Menards. Its a .250 ball bearing
pjberg #978011 10/11/2013 9:29 PM
' Offline
I'd consider the low risk option of
installing a GM NOS set of lifters.
These are very hard to find in decent
condition.
Here's a set on ebay.
photo at photobucket
http://i669.photobucket.com/albums/vv57/glp0329/spotting/GM5230650_zpsbdce634c.jpg
http://www.ebay.com/itm/321191571371?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
You can always send the seller a message
asking him if he'd take an offer.
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
pjberg #978047 10/12/2013 12:37 AM
The lifter you are looking at are for 1950-52 engines. Those engines used steel cams. If you have a late 1954-62 engine, which uses a cast cam, I would not recommended using these.
My Blog
