6 members (Uncles51, Peggy M, dwreills, JW51, Millenimech, Chip O), 41 guests, and 1 robot.
Topics128,035
Posts1,055,446
Members48,422
#977129 10/08/2013 12:07 AM
I just painted my wife's '55 and I'm getting tiny bubbles forming on the surface as soon as I spray it. I'm using Restoration Shop Acrylic Enamel, and I'm using a Devilbiss starting line HVLP with a 1.3 tip, also tried a 1.8. I've never had this happen before, and the epoxy primer laid down really nice. I've tried adjusting the air pressure, reducing it, and changing tip sizes, but can't get rid of this problem. Anyone got any ideas as to what's causing this????
Jake T #977172 10/08/2013 2:31 AM
Y
Y Offline
Just a guess, could it be solvent pop?
Jake T #977200 10/08/2013 4:13 AM
How long between the epoxy and your paint?
What kind of filter system in your air supply?
Give me ambiguity
or give me something else
Jake T #977250 10/08/2013 2:11 PM
Agree with the solvent pop guess. Make sure you have
the proper solvent for the temperature you're spraying at.
Had to really watch it when I was spraying dope (butyrate
lacquer) on fabric aircraft skins.
DG
Denny G
Sandwich, IL
I've had the same problem using acrylic urethane. They are very small pock marks about the size of a needle point and much smaller than fish eyes. I attribute them to the fact I was impatient and didn't wait long enough time between coats of paint and also tried to lay down too heavy a coat. After wet sanding the bubbles and respraying they tend to come back in the same place unless they are completely sanded out.
Jake T #977362 10/08/2013 10:12 PM
Originally Posted by Jake T
... I'm getting tiny bubbles forming on the surface as soon as I spray it.
Isn't solvent pop...
water/oil vapor in line or too much air pressure are my guess.
Give me ambiguity
CASO #977460 10/09/2013 3:31 AM
The epoxy primer can said to let it flash for 60 minutes before topcoating, which is what I did. Then I wiped it down with acetone, then sprayed the color. Could the acetone be doing it????
Jake T #977471 10/09/2013 4:05 AM
definitely .... why the acetone wipe, was that recommended??
Jake T #977498 10/09/2013 9:33 AM
Why would anyone wipe fresh primer??????
It was my wife's idea, she was super paranoid that some dust settled on it. I didn't even think about it. clearly.
Jake T #977588 10/09/2013 9:06 PM
well seeing it's her car ..... she can sand it down wink
Flxible #977634 10/10/2013 12:57 AM
haha, yeah, that's kinda what I figured,, I'm sure we'll both be having fun sanding this weekend now
Jake T #977646 10/10/2013 1:21 AM
And get her a package of tac rags as a thank you!
Give me ambiguity
