7 members (JW51, baldeagle, Dennys28, Bill Hanlon, Peggy M, Maybellene, Southerntruck),
62
Mod | | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | I have a 1951 235 with hydraulic lifter and #6 intake lifter is noisy. with the engine running and valve cover off I can push the rocker down with my hand and the ticking gets louder. Now is there any fix for that or do I just replace the lifters. engine casting #3692703 = 1951 235 passenger car with power glide | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You can remove the lifter and take it apart and clean it. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There can be two things that cause a spongy lifter. Trapped air or a dirty check valve. You may want to read my BLOG on this topic.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | Would the check ball inside the lifter be the problem if its all pitted | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Yes, that can prevent it from sealing against the seat.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | Correct me if I'm wrong, but it is NOT a good idea to install a new lifter on a used camshaft or vice versa.
Daryl
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is always best to keep lifters matched to the lobe they are worn into. Never use a used lifter on a lobe it is not removed from. Although there is a small risk you can usually get away with using a new lifters on a used cam.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | Where can I find a new check ball. Mine is all pitted | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What size are they? Loose ball bearings are available. You may even be able to cut apart an old bearing to get a ball out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | I found one ball bearing at Menards. Its a .250 ball bearing | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | I'd consider the low risk option of installing a GM NOS set of lifters. These are very hard to find in decent condition. Here's a set on ebay. photo at photobucket http://i669.photobucket.com/albums/vv57/glp0329/spotting/GM5230650_zpsbdce634c.jpghttp://www.ebay.com/itm/321191571371?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 You can always send the seller a message asking him if he'd take an offer. George in New Jersey | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The lifter you are looking at are for 1950-52 engines. Those engines used steel cams. If you have a late 1954-62 engine, which uses a cast cam, I would not recommended using these.
