2 members (Patina 54, 3800GUY),
225
Mod | | | Forums66 Topics128,098 Posts1,056,167 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 13 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 13 | Would it be possible for me to swap my entire body from my 1960 LWB C10 over to a 1994 1500 chassis? Or would it be better to swap front and rearend with 1971/72 running gear for the discs?
1960 Apache 10 LWB Custom Cab Stainless Trim Package
| | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | I have a 60 swb. I put spindles, disk brakes and hubs on the front from 81 Malibu. On the rear I have the axle fron 82 Indy pace car camaro. Then I used the master cyl and booster from the camaro. Works great! The only parts that were made were the lower ball joints and saddle that the rear axle sits in. I think the rest of the parts were off the shelf. If that is something you are thinking about doing pm me and I will work on all the info
Rh | | |
