1 members (stlcardinalsguy), 71 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#976828 10/06/2013 10:13 AM
is there a way to positively tell the difference between reproduction hubcaps and the original ones. From my 1941 chevrolet pickup.
eyell #976956 10/07/2013 2:01 AM
The original hubcap will have an outer skin crimped over the
inner actual hubcap. The reproduction hubcaps are only one layer.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
eyell #977053 10/07/2013 5:37 PM
Not true, my repros have an outer skin crimped over the inner cap as well.
My 46 GMC on Photobucket
eyell #977237 10/08/2013 1:09 PM
All the originals I've seen have the letters BLC stamped on the inside cap, which was probably the vendor GM sourced them from. Some have Made In USA along with the BLC mark.
eyell #977246 10/08/2013 1:51 PM
Must be different than the AD caps then. The four repops that I
bought from Chevy Duty for my 50, 3600 were all single layer.
I'll try to post a couple of pictures later.
http://www.pbase.com/dennygraham/image/152778730
http://www.pbase.com/dennygraham/image/152778731
I don't have an example of the Art Deco hubcaps so you obviously
have a better handle on the earlier reproduction hubcaps than I
do. Sorry for misleading the group.
How's it goin' Bob, anything new going on in your shop???
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #977293 10/08/2013 5:23 PM
Denny Graham
Sandwich, IL
All reproductions are not the same. I'm sure there are vendors that do it the cheap way and those that do it the right way. On this old stuff it's hard to know what you'll get.
eyell #977392 10/09/2013 12:41 AM
Hey there GMC, you wouldn't happen to have a picture of those
double layer reproduction hubcaps would you??? I'd like to add
that to my reference files.
Also it would be helpful to know where you got them from so the
next guy can get ones that are more like the original ones.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
eyell #984505 11/08/2013 11:39 AM
ok back to the hubcaps. does anyone know where i can find blue letter decals for a 1941 chevrolet pickup hubcap?
Denny Graham #984570 11/08/2013 5:19 PM
Denny Graham
Sandwich, IL
I don't have a picture of the back side of them. I'll try to get a picture when I can get easier access to the truck.
eyell #984571 11/08/2013 5:20 PM
If you can take your hubcap to a local sign place they should easily be able to make you decals in the correct color. The letters on my hubcap are painted or something and I think most aftermarket ones are, so you may not find the vinyl letters from a vendor.
eyell #984788 11/09/2013 12:44 PM
ok, guess i will mask them off and paint by hand.
eyell #984839 11/09/2013 5:13 PM
I bought this liquid masking film at a local hobby shop when I was preparing to paint the bowties on my '54 hubcaps. It might help mask the curves on your hubcaps. Lay it on thick and cut out the area to be painted with an Exacto knife. Don't know if the knife will damage the chrome.
> Masking Film
I ended up not using the liquid because my bowties are mostly straight. So I used 1/4" 3M Vinyl Tape 471+ masking tape instead. Burnish it onto the hubcap and paint will not creep under it. The 1/4" width allows the tape to follow a curved line. Also available in 1/8" width.
> 3M Vinyl Tape 471+
1-Shot sign painter's paint may be a good choice for paint. Flows out smooth by brush, or can be thinned and sprayed. Info in this post:
> Red & Blue hubcap paint
- Lonnie
- Lonnie
My '54 3104
