0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | is there a way to positively tell the difference between reproduction hubcaps and the original ones. From my 1941 chevrolet pickup. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The original hubcap will have an outer skin crimped over the inner actual hubcap. The reproduction hubcaps are only one layer.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Not true, my repros have an outer skin crimped over the inner cap as well. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | All the originals I've seen have the letters BLC stamped on the inside cap, which was probably the vendor GM sourced them from. Some have Made In USA along with the BLC mark. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Must be different than the AD caps then. The four repops that I bought from Chevy Duty for my 50, 3600 were all single layer. I'll try to post a couple of pictures later. http://www.pbase.com/dennygraham/image/152778730 http://www.pbase.com/dennygraham/image/152778731I don't have an example of the Art Deco hubcaps so you obviously have a better handle on the earlier reproduction hubcaps than I do. Sorry for misleading the group. How's it goin' Bob, anything new going on in your shop??? Denny Graham Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Must be different than the AD caps then. The four repops that I bought from Chevy Duty for my 50, 3600 were all single layer. I'll try to post a couple of pictures later. http://www.pbase.com/dennygraham/image/152778730 http://www.pbase.com/dennygraham/image/152778731I don't have an example of the Art Deco hubcaps so you obviously have a better handle on the earlier reproduction hubcaps than I do. Sorry for misleading the group. How's it goin' Bob, anything new going on in your shop??? Denny Graham Sandwich, IL All reproductions are not the same. I'm sure there are vendors that do it the cheap way and those that do it the right way. On this old stuff it's hard to know what you'll get. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey there GMC, you wouldn't happen to have a picture of those double layer reproduction hubcaps would you??? I'd like to add that to my reference files. Also it would be helpful to know where you got them from so the next guy can get ones that are more like the original ones. Thanks Denny Graham Sandwich, IL
| | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | ok back to the hubcaps. does anyone know where i can find blue letter decals for a 1941 chevrolet pickup hubcap? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Hey there GMC, you wouldn't happen to have a picture of those double layer reproduction hubcaps would you??? I'd like to add that to my reference files. Also it would be helpful to know where you got them from so the next guy can get ones that are more like the original ones. Thanks Denny Graham Sandwich, IL I don't have a picture of the back side of them. I'll try to get a picture when I can get easier access to the truck. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | ok back to the hubcaps. does anyone know where i can find blue letter decals for a 1941 chevrolet pickup hubcap? If you can take your hubcap to a local sign place they should easily be able to make you decals in the correct color. The letters on my hubcap are painted or something and I think most aftermarket ones are, so you may not find the vinyl letters from a vendor. | | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | ok, guess i will mask them off and paint by hand. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I bought this liquid masking film at a local hobby shop when I was preparing to paint the bowties on my '54 hubcaps. It might help mask the curves on your hubcaps. Lay it on thick and cut out the area to be painted with an Exacto knife. Don't know if the knife will damage the chrome. > Masking FilmI ended up not using the liquid because my bowties are mostly straight. So I used 1/4" 3M Vinyl Tape 471+ masking tape instead. Burnish it onto the hubcap and paint will not creep under it. The 1/4" width allows the tape to follow a curved line. Also available in 1/8" width. > 3M Vinyl Tape 471+1-Shot sign painter's paint may be a good choice for paint. Flows out smooth by brush, or can be thinned and sprayed. Info in this post: > Red & Blue hubcap paint- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
