| | | Forums66 Topics128,127 Posts1,056,674 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 14 New Guy | | New Guy Joined: Jul 2012 Posts: 14 | Is there a easy swap for a steering box I am putting a v 8 in it and looks like its hitting. | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Chassis Engineering in Iowa makes a very nice bolt on rack and pinion independant suspension set-up. Just purchased for my 47 GMC truck. I plan on using modified stock steering shaft with the original wheel.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | My buddy was able to move the box outboard just a bit and then used 55-56 exhaust mnfld that dumps out forward. Or you could make some tube headers to clear also. | | | | | Joined: Jul 2012 Posts: 14 New Guy | | New Guy Joined: Jul 2012 Posts: 14 | Thanks I will try moving it first trying to keep as original as possible right now, but thanks for the input it all helps. | | |
