0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | I just painted my wife's '55 and I'm getting tiny bubbles forming on the surface as soon as I spray it. I'm using Restoration Shop Acrylic Enamel, and I'm using a Devilbiss starting line HVLP with a 1.3 tip, also tried a 1.8. I've never had this happen before, and the epoxy primer laid down really nice. I've tried adjusting the air pressure, reducing it, and changing tip sizes, but can't get rid of this problem. Anyone got any ideas as to what's causing this???? | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Just a guess, could it be solvent pop? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | How long between the epoxy and your paint? What kind of filter system in your air supply?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Agree with the solvent pop guess. Make sure you have the proper solvent for the temperature you're spraying at. Had to really watch it when I was spraying dope (butyrate lacquer) on fabric aircraft skins.
DG
Denny G Sandwich, IL
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I've had the same problem using acrylic urethane. They are very small pock marks about the size of a needle point and much smaller than fish eyes. I attribute them to the fact I was impatient and didn't wait long enough time between coats of paint and also tried to lay down too heavy a coat. After wet sanding the bubbles and respraying they tend to come back in the same place unless they are completely sanded out. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | ... I'm getting tiny bubbles forming on the surface as soon as I spray it. Isn't solvent pop... water/oil vapor in line or too much air pressure are my guess.
| | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | The epoxy primer can said to let it flash for 60 minutes before topcoating, which is what I did. Then I wiped it down with acetone, then sprayed the color. Could the acetone be doing it???? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | definitely .... why the acetone wipe, was that recommended??
Bill | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Why would anyone wipe fresh primer??????
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | It was my wife's idea, she was super paranoid that some dust settled on it. I didn't even think about it. clearly. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well seeing it's her car ..... she can sand it down  Bill | | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | haha, yeah, that's kinda what I figured,, I'm sure we'll both be having fun sanding this weekend now | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | And get her a package of tac rags as a thank you!
