3 members (Wally / Montana, Guitplayer, Jon G), 126 guests, and 1 robot.
Topics128,130
Posts1,056,717
Members48,454
Does anyone have the measurements for relocating the pivot for the throttle linkage from a '38 TD 216 to a 1962 235? Also, what hardware is used? Is that pivot threaded or pressed into the 216? Ive seen some pics from pre68 Dave, not sure if he re-uses the pivot, or fabs it.
Thanks!
Oh, the engine runs smooth, except for a vacuum leak, the alignment ring at #1 cocked as it was going in. Had to pull it off to drill for the pivot anyway, but got to hear it run!
Sorry I did not get back to you with the measurements. I am on vacation for another week and do not have them with me.
Anyone with a 1937-60 216 or 235 could give you the front pivot measurement.
My Blog
Ok, no worries! Enjoy the vacation! Hard to come by!
Is the pivot pressed in, or threaded originally?
Roughly
12 9/16 inch from center of belcrank to rear
1954 car 235 on a 1950 3100
Wait to hear from Pre68Dave or others to confirm
My belcrank is threaded ...pic...
Just found this in one of my old posts.
The mounting hole should be 12 9/16" from rear of block and 4.850" down from the deck of the block.
Yes, they are threaded in.
My Blog
The bellcrank in several pictures has a hex base on the block end. The one I have access to doesn't. I've soaked it with penetrant, heated it etc. I don't want to scar it. Are the early ones also threaded? Are they available?
All factory bellcrank pivots have a hex base.
What pictures are you referring to?
In the picture in THIS LINK you can see what the 1941-62 pivot looks like, 1938 is similar but has a bigger hex and a nut on the outboard end to hold the arm on. The hex in the block in this picture is a 1/4" pipe plug I used to replace the missing mounting position on 1960-62 engines.
My Blog
I wish I were home where I have more pictures, but I an wondering it you are talking about the post that the return springs attach to on a 1937-40? That does not have a hex, it is driven in.
When I get home next week I can post some pictures of that conversion I have done.
Can you post a picture of what you have?
My Blog
It is a threaded fitting.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
