3 members (chemanic, Otto Skorzeny, Mike Roache), 76 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
#976652 10/05/2013 1:33 PM
I want to drop the oil pan on this engine. Is there enough clearance to get it out with engine in place? It looks mighty tight.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #976657 10/05/2013 2:03 PM
you'll have to take the bottom nut off the front motor mount under the cross member and jack the front of the engine up about 3"... but yes is the answer and yes it's very tight on the front corner bolts in particular.
Give me ambiguity
or give me something else
jmoore #976719 10/05/2013 7:45 PM
Thanks for the insight.
1957 GMC 150
