3 members (panic, 2-Ton, 1 invisible), 133 guests, and 3 robots.
Topics128,260
Posts1,058,343
Members48,485
#975259 09/29/2013 2:40 PM
Anyone taken the stock center from the 17" split rims and put a later model hoop?
I really like the stock center caps and wheel center, if I could get rid of the split rim so when I get my truck on the road I could take a flat to a shop to get fixed if I need to.
AntiBling #975310 09/29/2013 6:54 PM
Why can't a flat shop do it? I have done my own as well as a flat shop doing it, what is wrong with them?
AntiBling #975314 09/29/2013 7:24 PM
1 Offline
It is SPENDY but I went the Stockton Wheel route, sending my 4 centers , the cut them down and welded the centers to 16'" solid outer rims. I then mounter radial tires on those and have absolutely NO regrets except the cost
Murraydave #975465 09/30/2013 12:51 PM
In some states it's illegal for shops to do them because there is the possibility when airing it up and the bead sets the ring blowing off. At the shop I worked at we had a big cage that you would put the tire in and clip on an air chuck from the tire machine and air it up.
Here's a video of what can happen. Most of the time it's because the wheels are in poor shape, rusty, dirty, and worn.
This is what I'm wanting to do with mine... but do it myself. Cutting the centers down and chucking it on a lathe and welding isn't a problem, I'm just wanting hoping someone else has done this and already knows a wheel from a later model that is suitable with minimal cutting of the center.
AntiBling #975478 09/30/2013 1:39 PM
Originally Posted by AntiBling
...I'm just wanting hoping someone else has done this and already knows a wheel from a later model that is suitable with minimal cutting of the center.
Absolutely zero cutting if you use 8 lug 19.5" wheels center all; just bolt them on your truck and drive. It'll take a little searching but it's by far the easiest method of running tubeless wheels on these old trucks.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #975485 09/30/2013 2:20 PM
Grigg
Is this an AD wheel? I don't really want to go as large as 19.5" but what did these wheels come on?
AntiBling #975502 09/30/2013 3:56 PM
19.5" wheels are not original on an AD truck but they are a great upgrade. They came out about 1956 and were used for many years on some (certianly not all) 1 tons, step vans, NAPCO 1 ton trucks, and even on some similar ford trucks.
With 8R19.5 tires they're about 32" tall. That is a tad taller than 7.50-17 tires, helps with road speed, and nicely fills the fenders. Still a tall skinny tire look, many people don't notice they're non original.
Grigg
---All pictures---
AntiBling #975516 09/30/2013 4:40 PM
The main goal is to run the stock hub caps and eliminate the split rim. I plan on updating the driveline so gaining road speed isn't really an issue.
AntiBling #975561 09/30/2013 7:48 PM
Why not just get new rims all together? Just add hub cap clips.
http://www.laroke.com/larryk4674/smokey_culver/hubcaps.htm
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #975675 10/01/2013 10:04 AM
Because I'm picky about my wheels, I like the smooth center the stock wheels have, I don't care for the outside nubs modern steel wheels have.
Was just wondering if anyone had done what I'm talking about, could save some time on searching for the right donor wheel.
AntiBling #975860 10/01/2013 9:44 PM
The new Ford E250 and E350 wheels come without the center nubs. They are almost identical to the older wheels.
Look for take offs from a 2007 and newer.
"The Fake Truck"
AntiBling #975900 10/01/2013 11:47 PM
Late model Chevrolet stuff also doesn't have the hubcap nubs. Check this out: http://www.ackerwheels.com/wheels/AW1619.html
Looks like 1988-2002 is the era for them.
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
AntiBling #976536 10/04/2013 8:42 PM
You would have to watch the backspacing on those, as it is about an inch deeper than what the original wheels used. The E250/E350 wheels will fit better.
Now a word on the whole split rim issue; most modern tire shops simply do not want to put the money or training time into handling obsolete split rims, it's simply not worth it to them. As mentioned in an earlier post, in some places it's even illegal for them to be serviced. Even shops that handle big truck tires are getting away from them, as for the most part, even heavy trucks do not use splits anymore.
Bill Burmeister
Whitedog #976585 10/05/2013 2:04 AM
1999 and newer Ford 8 lug bolt pattern is 8x170mm which will not work on GM 8x6.5"(165.1mm) 98 and older Ford and all Dodge are 8x6.5" bolt pattern so there are a lot of possibilities to check out. Also all 2011 and newer GM 8 lug single wheel bolt patterns are 8x180 and the duallys are 8x210.
AntiBling #976702 10/05/2013 6:10 PM
That's only on the F 250 and 350. The E 250 and 350 vans still have the old 8x6.5 bolt pattern.
Bill Burmeister
Moderated by  Dusty53
