4 members (Chip O, Hotrod Lincoln, TooMany2count, 1 invisible), 88 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#97624 10/16/2006 10:31 PM
Hello, gents. longtime reader and visitor to this great site. I just picked up a complete heater for these ol' trucks name tag say's Harrison i believe. it has an round aluminum plate with chevrolet on it. anyhow i want to check if the motor turns. without burning somthing up, can i connect the two wires (neg and Pos.) at the motors end to a 12 volt battery direct or should i use a reducer to bring it down to 6 volts.
the heater looks to be in excellent shape and i intend to put in my 51. thanks.
#97625 10/16/2006 10:46 PM
Ex Hall Monitor
Ex Hall Monitor
I ran my 55 1st panel heater motor on 12 volts for several years without problem. Having said that the safest way would be to hook it to six volts. I converted it to 12 volts and never thought about the heater motor. The gas gauge worked OK too. I'm not saying you should do the same, I may have just been lucky.
#97626 10/16/2006 11:13 PM
Red dot, center of chest ...
The best thing to do is buy a 12 volt motor and put that in, but the six volt motor runs on 12 volts. (Mine ran slowly, which is why I switched to a 12 volt motor.) You can pick up a 12 volt motor that will work at Grainger.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#97627 10/17/2006 2:56 PM
Ex Hall Monitor
Ex Hall Monitor
eek After all these years I finally find out why the heater fan in the old panel turned so slowly. It put out so little air that it was worthless as mammaries on a man. I always assumed (I know, I know) that a 6 volt motor would turn faster on 12 volts. It's counter intuitive but I sure can't call you wrong. grin
#97628 10/17/2006 4:23 PM
JACOB,
As Tiny indicated, testing the 6 volt motor on 12 volts certainly wouldn't be instant death for it, and it appears he has run his on 12 volts for years.
If it works on 6 volts, leave it alone. The Grainger 12 volt is not a direct swap for the stock unit.
Using a replacement 12 volt motor on your factory 6 volt system might give you a 'slow motion' motor (Tiny)...which could result in frozen mammaries! eek
Stuart
#97629 10/21/2006 2:26 AM
Sounds like a deluxe heater is what you got. I hope it is complete like you said, but I will point out that a complete deluxe heater will also need a temperature control valve, defroster outlets, heater switch, and defroster control cable.
