2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#976281 10/03/2013 1:28 PM
I have a 52 Chevy 3100 pickup with a rebuilt generator. For the battery to charge effectively, is there a certain speed/duration I need to go? Thanks.
are you having problems? a generator won't charge much, if at all, at idle, but under normal conditions the discharge from starting should be made up pretty quick once you get above idle, particularly driving it - there's not really a "formula" because time depends on the state of charge of the battery
