| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I have a 52 Chevy 3100 pickup with a rebuilt generator. For the battery to charge effectively, is there a certain speed/duration I need to go? Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | are you having problems? a generator won't charge much, if at all, at idle, but under normal conditions the discharge from starting should be made up pretty quick once you get above idle, particularly driving it - there's not really a "formula" because time depends on the state of charge of the battery
Bill | | |
