5 members (farmallb, klhansen, Peggy M, KingG, 1 invisible), 58 guests, and 4 robots.
Topics128,024
Posts1,055,393
Members48,422
#97619 10/15/2006 9:13 PM
I have a steering column from a '74 Buick in my '49. I replaced the neutral safety switch and as soon as I tried to start it a wire burned. Had to install a push button switch to start it. What I need to know is just where do the 2 wires plug onto this switch? There's several places. Think maybe I plugged into a wrong one and made the wire burn. Also, which spot would be the one to hook up backup lights? Thanx
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#97620 10/16/2006 7:25 PM
I used a caddy steering column... i checked where each wire was supposed to go according to the OEM diagram, then checked it with a multimeter to make sure it was doing what it was supposed to do... no burned wires.
Another quality post.
Real Trucks Rattle
#97621 10/18/2006 2:05 AM
pablos, there should be 2 prongs on the left side of the switch, one on top of the other. This is the ones you want . the other prongs are in the middle of the switch, side buy side, and they are for the backup lights.Hopes this helps!
#97622 10/18/2006 11:14 AM
Thanx Hot Rod. That's the info I was looking for. I'm going to rewire it this spring and I wanted to make sure I knew where everything went. My goal is to pass the NSRA safety inspection. Why? I dunno, maybe 'cause it's there!
#97623 10/19/2006 12:02 AM
pablos, glad to help, and the NSRA safety program is really a great thing. Every car,or rod I,ve built(15)? has passed it. Just makes you feel good to know it does!!!
