0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I've seen some posts about moving the gas tank from the cab to under the bed but usually it is at the rear of the truck. I'm looking to put it under/behind the cab and under the bed. I like the filler used on the Dodge Lil Red Express trucks and having it plumbed into the sheet metal just below the bed and just behind the cab. Anyone know of a tank of at least 15 gallons that fit there?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | check out the 80's chevy truck or look at rci fuel cells they make all shapes. then you can have a neck welded in where you need it | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | My guy fans them up any shape or size to fit where you want...uses heavy gauge aluminum. Cost is way less than SS tanks sold commercially.
I may have him one for me just cuz I don't like sitting next to all that gas in the cab...also get fumes in winter with windows closed | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks for the replys guys. I want to go the metal route. I know the polypropylene is used all the time but I still feel funny about it. It's in our PT Cruiser though. moff's is so custom, It doesn't really help me to see what would work for me. But, I would like to have all that capacity for sure.
I've thought about having one made too but there is probably something I could adapt. I've got a while before I get to this piece of the puzzle so right now just looking for options.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Dennis, I have a '39 and I got my gas tank from Rick's Tanks out of El Paso. The gentlemen from Ricks was working on a '39 as well and already had a tank in the works. It fits behind the rear axle with out any modification, boxing, or removing the rear cross member. It came with side tabs that needed to be welded to the rear frame. If I am not mistaken, it is a 26 gal tank. Get a hold of Ricks and see what they can do for you. They might be able make a tank to your specs. I hope you find what you are looking for and keep us updated once you find one that works for you. I'm interested in what you come up with. Bread .
| | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Maybe I just like to take the rough road, but I want to place the tank within the side rail toward the cab, not behind the diff. Anyone placed one there?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | side rail gas tank relocation This guy has some great info on what he did. I am not sure if it will work on yours but this is what he did on his task force.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks. Yep, that is about what I'm going for. I will probably go for a generic tank unless I find something that fits especially well on the '40.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Look at an S-10 tank, the big one. They mount to the inside of the frame rail. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I was reading another post here check out what this guy did. here is some of the pics he link to his build GasTank 1940 chevy build
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks Tiny. Yeah, I've seen the Jag build. It is way modified so doesn't really look like a '40 underneath. I feel like I'm doing a lot of things but you wouldn't think so after looking at what he is up to.
Dennis
40 Chevy 1/2 ton
