4 members (Maybellene, klhansen, 2 invisible),
87
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | Does anyone have photos they can share showing a good / clean / neat installation of wire or wire loom routed through the rear frame? I am quite an assortment of wire types from the cab to the rear (including speaker wire) that I am going to replace while I have the bed removed. I'm not going to replace the entire harness, just those going to the rear lights.
I'm looking for the connections to the frame as well as the bundling of the wire or wire loom.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Since I took my bed off I can see my wiring, its partially unhooked from the frame, but when I get home I'll take a look/picture and see if it helps you out at all... no promises it will though | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I finally re-wired all the tail lights and pulled new wire up to the firewall. I put some 7/16" wire loom along the frame with some nice clips to the frame. I put in new chrome wire loom to the tail lights ( many purists argue that is not stock, but I really like the look). I tried to make everything as clean and neat as possible and pretty pleased with the results since this is my first time doing something like this. Frame & tail-light wiring | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | That looks really good Bob! | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I'm really pleased with the outcome. I just need to determine a way to secure the finishing cap on the back of the tail light. It has small indendations that should fit into something in the tail-light with matching recesses (which don't exist). I may take some clear silicone and just "glue" the finishing cap onto the back of the tail-light. Everything else looks great - trying now to do some nice long-lasting labels for the wires. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | 3/8 flex tubing. Nice! Too much time in the electrical isle, right? | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | You are right about that. I went to an auto parts store, then Radio Shack but actually found most everything I wanted at Home Depot. | | |
