1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#975266 09/29/2013 2:56 PM
My truck is a 53 and when I got it the front motor mount was not attached cuz it didn't have the two bolts attached to the mounting plate . After researching the engine casting numbers it is a later 235 from 56,57 . If I change the mounting plate that has the two carriage bolts and install it on the motor will it fit into my truck because it is a later engine block ?
Yep, it'll fit. You can change the mounting plate or just drill the holes in the one you.
Drew
I just drilled the holes and used locking bolts. Much faster and easier.
Ok that's cool .. What is the difference between 216 and 235 motor ?
In 25 words or less?
216ci - 1937-1953
low pressure lubrication system
babbetted rod bearings
dipper/spray oiling to rod bearings
235ci - 1941-1952
1953 235 - complicated differences in this "transition" year
1954-1962/63
235ci (and 261ci)
high pressure internal lubrication system
insert rod bearings
internal oil feed through crankshaft to rod bearings
Many minor changes in these engines during their production years.
