6 members (68ironhead, cmayna, Eisenholtz, joe apple, JW51, 66flea), 70 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#975319 09/29/2013 7:58 PM
I am running a 54 3100 235. I am having issues with the engine getting hot. I drive 30 miles one way at about 55-60 mph and after 10 mins of driving I can feel the heat through the firewall.
I just had the engine rebuilt, new water pump, new radiator. What else can I do?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
maybe you need more insulation on the firewall - is the truck actually overheating? - what does the temp gauge say? have you checked the actual temp with a good laser thermometer?
The temp gauge is not hooked up, I do not have numbers to back up my claim, I just feel alot of heat coming through the firewall and even when I shut down and look under the hood. Bill you may be right that its not actually overheating but I am concerned that it is.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
get a laser thermometer and check around the engine and rad when you feel it's up to "hot", you might be surprised how much heat gets transfered thru the firewall, and how hot it gets under the hood, just at normal operating temp
I had the transmission rebuilt and the rear end replaced. I can happily say I am no longer having issues with the overheating. I imagine the rear end was causing some resistance.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
