| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | My truck is a 53 and when I got it the front motor mount was not attached cuz it didn't have the two bolts attached to the mounting plate . After researching the engine casting numbers it is a later 235 from 56,57 . If I change the mounting plate that has the two carriage bolts and install it on the motor will it fit into my truck because it is a later engine block ? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Yep, it'll fit. You can change the mounting plate or just drill the holes in the one you.
Drew
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I just drilled the holes and used locking bolts. Much faster and easier. | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Ok that's cool .. What is the difference between 216 and 235 motor ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 25 words or less?
216ci - 1937-1953 low pressure lubrication system babbetted rod bearings dipper/spray oiling to rod bearings
235ci - 1941-1952 low pressure lubrication system babbetted rod bearings dipper/spray oiling to rod bearings
1953 235 - complicated differences in this "transition" year
1954-1962/63 235ci (and 261ci) high pressure internal lubrication system insert rod bearings internal oil feed through crankshaft to rod bearings
Many minor changes in these engines during their production years.
