Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy), 57 guests, and 2 robots.
Topics128,008
Posts1,055,285
Members48,418
#975123 09/28/2013 10:24 PM
Do I have to change the headlight switch when I go from 6v to 12v?
generally no
what are you working on?
46 2 ton chevy
the reason i ask is that i see 6v and 12 v light switches on jim carter
You will have no problems running 12v on an original switch
I'm not sure about the aftermarket switches.
With any switch, the rule should be: If it worked on 6V it will work on 12V, If it is a 12V it may not work on 6V.
With switches and wires it is all about Amps not Volts.
6V systems carry more amps to get the same work done than 12V systems.
