0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | Hey All
I got a passenger side mount from chevs of the 40s. its flat, and therefore doesnt mount onto the frame of my 2 ton.
is there a piece out there Im missing, or am I just gonna have to fabricate something. Bending it at a 90 would probably work as well.
just seeing what y'all have done on your trucks for a passenger side light (using the same style as the driver side light) | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Do you just have a cab and chassis or do you have a body on it. It was common to have just one light on the driver side or if there were two, they were usually on the body. You will probably have to fabricate something. | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | its a 2 ton, so its a cab and chassis. the drivers side light mounts on the frame | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It probably never had a light on the curb side. | | |
